KRM
Jun 06, 2011"emerg logger: Re-starting tomcat"
Hi all,
My previous post was related with this issue but it looks fine now. I imported an ucs to LTM 3900.
I captured the output below when i run "show system" Looks odd :
I may continue by going back to factory settings or restoring to a stable state but for any of them i need to do this on tmos shell ..
any advice will be appreciated...
- The_Bhattman
Hi KRM,
A method that i have tried before is booting to a different partision which has the same version and then performing a restore from there. Have you looked into that?
Thanks,
Bhattman - KRM
Thanks for your help, i booted from other partition to solve the problem...
