SoumyaBasu_3529's avatar
SoumyaBasu_3529
7 years ago
emerg logger: Re-starting restnoded"
I have two Ltm in HA mode. Suddenly, I start receiving the below log message in both the ltms :
"emerg logger: Re-starting restnoded" What could be the issue? How can I solve this issue. Any help will be highly appreciated.
  • As you can see here https://support.f5.com/csp/article/K45092482, "restnoded" is the daemon to handles iControl REST queries.
    Check logfile to see if more info is included in "/var/log/restnoded.[0-9]*.log" or "/var/log/restnoded/restnoded.log"
    This should only affects to REST queries handling. Are you dealing with iWorkflow in your solution?
    Here you can fine a similar problem with solution: https://devcentral.f5.com/wiki/iWorkflow.HowToSamples_iworkflow_js_samples.ashx
    Hope this help.
  • Thanks for your reply .
    Ok .. When I check the restjavad logs ... Guess what there are 9 to 10 java heap space error. So my device doesnt have the memory to run the restnoded service . I restart the Restjavad service and seems everything is fine now. I am keep an eye on the logs so far , but the services are running for 8 Hr now.
