MichaelJordan_1's avatar
MichaelJordan_1
Aug 21, 2015
Edge Client Layout Customization
Hi
I would like to ask that is it possible to remove/disable "Autoconnect" button on Windows Edge Client ? I could not find a way to achieve this.
  • Hi,
    You should be able to remove the network awareness values and uncheck the Auto launch BIG-IP Edge Client.
    Seth
