David_G__33241
May 01, 2015Edge Client Installation
I am using MSIEXEC to deploy the Edge Client using the following paramaters:
msiexec /i f5fpclients.msi /qb! /promptrestart
This works fine however if a previous version already exists then the installer gives a message indicating that it is already installed. Is there a command line option to simply install if it is the first time or overwrite if it already exists regardless of the version? Do I need to use a transform file?
Thanks...
Try this
MsiExec.exe /i "f5fpclients.msi" STARTAPPWITHWINDOWS=1 /qn REBOOT=ReallySuppress /l* c:\build\logs\F5BIGIPClient.log ARPNOREMOVE=1 ARPNOMODIFY=1 ALLUSERS=1 REINSTALLMODE=vomus REINSTALL=ALL
- kunjan
Try this
MsiExec.exe /i "f5fpclients.msi" STARTAPPWITHWINDOWS=1 /qn REBOOT=ReallySuppress /l* c:\build\logs\F5BIGIPClient.log ARPNOREMOVE=1 ARPNOMODIFY=1 ALLUSERS=1 REINSTALLMODE=vomus REINSTALL=ALL- David_G__33241
I knew that! ;-) Thanks, kunjan - it works great!
- kunjan_118660
Cumulonimbus
Try this
