Dynamic Ratio Load Balancing
We have an API that automatically inserts servers into a load balanced pool. The pool uses dynamic load balancing and the permanent servers in there have WMI monitors which seem to be working well. The issue is the automation doesn't create the node with a WMI monitor hence we have servers sat in the pool with no monitor and servers sat in the pool with monitors.
All the servers are up and passing traffic. However, I cannot ascertain what ratio the servers without WMI have been given. Does anyone know on what basis the F5 sends traffic to the non-WMI servers?
Thanks Mark
- nitass
Employee
I cannot ascertain what ratio the servers without WMI have been given. i understand it is 1.
The node is not returning SNMP data in the correct format. If the BIG-IP system cannot interpret the data returned by the SNMP DCA monitor, it sets the weight of the node to 1.sol9125: Overview of Dynamic Ratio load balancing
http://support.f5.com/kb/en-us/solutions/public/9000/100/sol9125.html
e.g.200.200.200.101 is linux without wmi agent, 200.200.200.103 is windows 2003 with wmi agent root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm node ltm node 200.200.200.101 { address 200.200.200.101 monitor mywmi session monitor-enabled state up } ltm node 200.200.200.103 { address 200.200.200.103 dynamic-ratio 113 monitor mywmi session monitor-enabled state up } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor wmi mywmi ltm monitor wmi mywmi { agent "Mozilla/4.0 (compatible: MSIE 5.0; Windows NT)" command "GetCPUInfo, GetDiskInfo, GetOSInfo" defaults-from wmi interval 5 method POST metrics "LoadPercentage, DiskUsage, PhysicalMemoryUsage:1.5, VirtualMemoryUsage:2.0" password password post RespFormat=HTML time-until-up 0 timeout 16 url /scripts/F5Isapi.dll username administrator } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm node dynamic-ratio ltm node 200.200.200.101 { dynamic-ratio 1 } ltm node 200.200.200.103 { dynamic-ratio 113 }
