Jon_Swick_29911's avatar
Jon_Swick_29911
May 22, 2017
Dynamic Ratio Load-Balancing - SNMP Monitor
I am looking to create a load-balancing method based on CPU. I understand i do this with dynamic and i create the monitor itself. I understand this part and it makes sense. I have included the kb articles that explain below to show what I have researched.
My question is ... How to validate. I am doing this in my lab so the ability to generate enough load to affect CPU is limited. Is there a way to check if the monitor is pulling snmp values and what those values are? Also is there a way to print the ratios are being assigned by the monitor?
https://support.f5.com/csp/article/K9125 https://support.f5.com/csp/article/K14110 https://support.f5.com/csp/article/K14114 https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_configuration_guide_10_0_0/ltm_appendixb_monitor_considerations.html
