haeoraki_127471
Mar 04, 2004Does BIG-IP system contain CORBA ORB, C++ or java Compiler?
Or for corba development, should I install ORB, C++or Java Compiler?
I couldn't find any orb, Java in BIG-IP system at my company. What's wrong?
- Like I mentioned in my other a BIG-IP is not a development system.
Compiling and running external applications on the BIG-IP is not supported and as far as I know our support system will not support the product if you've made modifications to the filesystem.
Any development and deployment of applicaitons will have to be done on separate machines.
iControl is a Software Development Kit that is meant to be installed on a development machine. The requirements for supported 3rd party software is detailed in the SDK.
If you have any questions about our support policies, feel free to contact F5 Technical Support.
Email: support@f5.com
Phone: 206-272-6888
Web: http://www.f5.com/support/
AskF5: http://tech.f5.com/
-Joe
