Livius's avatar
Livius
Icon for Cirrus rankCirrus
Jun 20, 2017
Do not delete persistence record when FIN flag is received
Hi All,
For my setup I would like to keep the persistence record in the memory even if a RST or FIN is sent. I would like to do that by means of iRules. Persistence records will be kept in memory as long as the session timeout will allow.
Thanks!
  • Hi,
    the main goal of persistence is to stay on the same server within a "session" on multiple TCP connections.
    if you enable persistence, it won't be deleted when TCP connection ends.
