Hoang_Hung's avatar
Jun 15, 2020
Disable TLS verion 1.0 and Reconfig Self-signed Certificate on Management Interface
Hi all
We have using have F5 running HA mode.
After check security recommned PCI DSS V3.2 we have 2 error release
  1. Disable TLS 1.0 Protocol Detection on Management Interface (using HTTPS)
  2. Reconfig Self-signed Certificate on Management Interface
Please help me config 2 issue it
Thanks all
Hung Hoang
  • NAG's avatar
    NAG
    HI Hoang,
    1) Disable TLS 1.0 Protocol Detection on Management Interface (using HTTPS)
    ANS: if you want to restrict to only TLS 1.1 and TLS 1.2 ciphers and disable use of TLS 1.0, then type the following command :
    #tmsh modify /sys httpd ssl-ciphersuite ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:!SSLv2:!SSLv3:!TLSv1
    #tmsh save sys config
    #bigstart restart httpd
    2) Reconfig Self-signed Certificate on Management Interface
    Ans:
    K42531434: Replacing the Configuration utility's self-signed SSL certificate with a CA-signed SSL certificate
    https://support.f5.com/csp/article/K42531434
    Hope this helps.
    Let me know if you have any questions,
    Nag
    • Hi
      What happent if i use command: #tmsh modify /sys httpd ssl-ciphersuite ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:!SSLv2:!SSLv3:!TLSv1
      >> I think it will Impact all running service on F5 deivice. We on apply on Management Interface..
      Please recommend to you.
      we only reconfig on Management interface.
      > Plz help me
      Thanks NAG
  • NAG's avatar
    NAG
    Hi Hoang,
    ANS: It will not impact all the services. It only applies to management GUI interface(configuration Utility) which is accessed via HTTPS.
    Here is the documentation from F5 your conformation.
    https://clouddocs.f5.com/training/community/public-cloud/html/class4/module2/mgmt-cipher.html
    May be you are thinking  Configuration utility and Management Interface are 2 different things. F5 calls Management interface as  Configuration utility.
    "Configuration utility = Management Interface"
    Therefore, following article is for management interface.
    Hope this helps.
    Thank you
    Nag
