Device Trust issue
java.io.IOException: Could not read response from server: ParseError at [row,col]:[1,235] Message: The processing instruction target matching "[xX][mM][lL]" is not allowed.
Running code 11.5.1
I am running vCMP, I am logged into the guest management IP. I created a isolated VLAN for HA configured both devices with different selfips and same floats. I cannot add other pairing device to device trust?
What are the steps for this? did I miss something?
- arpydays
When setting up device trust you need to enter the mgt IP of the peer guest device to establish the initial trust relationship. Also you do not need floating IPs on the isolated HA, as each device will talk to the peer directly no other traffic will use the vlan.
Follow this procedure and see how you go...
cheers
