Roman_80473
Nov 17, 2011Detect if node is half-dead with an iRule?
Hi folks,
I was tasked to monitor app servers in the pool with an iRule (LTM 10.2). I wrote a simple rule which does the following:
if I get into LB_FAILED, I take the node out and resend request
if I get into HTTP_RESPONSE, and http status >= 500, I take the node out and resend request
It only seems to be working when the nodes are either fine or completely dead. Otherwise, (server ran out of memory), request gets into LB_SELECTED, and sits there forever. I get "The connection to the server was reset while the page was loading" error in the browser after about a minute or two, but my iRule never kicks in.
Is there a way to detect that the node is "half-dead" with iRule? Or, there're some external configuration in the VIP, pool, etc?
Any help is greatly appreciated
Thanks, Roman
- hoolio
Hi Roman,
It sounds like the server is completing a three way handshake to accept the TCP connection, but not responding to the HTTP request. In that case, you could use the 'after' command to set a timer for how long to wait before taking some action. See the second example on the 'after' wki page for details:
http://devcentral.f5.com/wiki/iRules.after.ashx
Aaron - Roman_80473
Hi Aaron,
Where would I put the "after" command? The example talks about http_request, but since I never "technically" get there, do I need to put it in the next sequential event after LB_SELECTED, i.e. SERVER_CONNECTED or HTTP_REQUEST_SEND?
Thank you, Roman - hoolio
You set the timer in HTTP_REQUEST and then cancel it in HTTP_RESPONSE if a response is received within the timeout. You should be able to just modify the TCP::respond command to do whatever action you want (disable the pool member, select a new one, etc), but leave the events as they are.
Aaron - nitass
Employee
pool foo accepts 3-ways handshake but not responding any http request. i tried to re-select pool foo2 instead but i got - Address in use tcl error message (and of course, bigip sent reset to both sides).[root@ve1023:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve1023:Active] config b pool foo list pool foo { members 200.200.200.101:88 {} } [root@ve1023:Active] config b pool foo2 list pool foo2 { members 200.200.200.101:80 {} } [root@ve1023:Active] config b rule myrule list rule myrule { when RULE_INIT { set static::response_timeout 5 } when HTTP_REQUEST { log local0. "Received request, beginning response monitor interval. [clock seconds]" } when LB_SELECTED { set monitor_id [\ after $static::response_timeout { LB::reselect pool foo2 log local0. "Timeout $static::response_timeout milliseconds elapsed without server response. [clock seconds]" }\ ] } when HTTP_RESPONSE { log local0. "Received server response." if {[info exists monitor_id]} { log local0. "Canceling after script with id $monitor_id" after cancel $monitor_id } } } curl -i http://172.28.19.79 curl: (52) Empty reply from server Nov 18 00:16:02 local/tmm info tmm[4766]: Rule myrule : Received request, beginning response monitor interval. 1321604162 Nov 18 00:16:02 local/tmm err tmm[4766]: 01220001:3: TCL error: myrule - Address in use (line 1) invoked from within "LB::reselect pool foo2" 00:16:02.240879 IP 172.28.19.253.34199 > 172.28.19.79.80: S 3035055119:3035055119(0) win 5840 00:16:02.240917 IP 172.28.19.79.80 > 172.28.19.253.34199: S 2804861295:2804861295(0) ack 3035055120 win 4380 00:16:02.244080 IP 172.28.19.253.34199 > 172.28.19.79.80: . ack 1 win 46 00:16:02.244104 IP 172.28.19.253.34199 > 172.28.19.79.80: P 1:155(154) ack 1 win 46 00:16:02.244203 IP 200.200.200.10.34199 > 200.200.200.101.88: S 3752179749:3752179749(0) win 4380 00:16:02.244864 IP 200.200.200.101.88 > 200.200.200.10.34199: S 195117275:195117275(0) ack 3752179750 win 5792 00:16:02.244875 IP 200.200.200.10.34199 > 200.200.200.101.88: . ack 1 win 4380 00:16:02.244886 IP 200.200.200.10.34199 > 200.200.200.101.88: P 1:155(154) ack 1 win 4380 00:16:02.245899 IP 200.200.200.101.88 > 200.200.200.10.34199: . ack 155 win 54 00:16:02.249309 IP 200.200.200.10.34199 > 200.200.200.101.88: R 155:155(0) ack 1 win 4380 00:16:02.249333 IP 172.28.19.79.80 > 172.28.19.253.34199: R 1:1(0) ack 155 win 4534 - nitass
Employee
if i put LB::detach before LB::reselect, tcl was not error but after sending fin, bigip did not establish connection to pool foo2. i think because bigip already established connection to pool foo.[root@ve1023:Active] config b rule myrule list rule myrule { when RULE_INIT { set static::response_timeout 5 } when HTTP_REQUEST { log local0. "Received request, beginning response monitor interval. [clock seconds]" } when LB_SELECTED { set monitor_id [\ after $static::response_timeout { LB::detach LB::reselect pool foo2 log local0. "Timeout $static::response_timeout milliseconds elapsed without server response. [clock seconds]" }\ ] } when HTTP_RESPONSE { log local0. "Received server response." if {[info exists monitor_id]} { log local0. "Canceling after script with id $monitor_id" after cancel $monitor_id } } } curl -i http://172.28.19.79 ...no response... Nov 18 00:27:41 local/tmm info tmm[4766]: Rule myrule : Received request, beginning response monitor interval. 1321604861 Nov 18 00:27:41 local/tmm info tmm[4766]: Rule myrule : Timeout 5 milliseconds elapsed without server response. 1321604861 00:27:41.513841 IP 172.28.19.253.47126 > 172.28.19.79.80: S 2431649126:2431649126(0) win 5840 00:27:41.513884 IP 172.28.19.79.80 > 172.28.19.253.47126: S 3818007430:3818007430(0) ack 2431649127 win 4380 00:27:41.517039 IP 172.28.19.253.47126 > 172.28.19.79.80: . ack 1 win 46 00:27:41.517091 IP 172.28.19.253.47126 > 172.28.19.79.80: P 1:155(154) ack 1 win 46 00:27:41.517268 IP 200.200.200.10.47126 > 200.200.200.101.88: S 1242901181:1242901181(0) win 4380 00:27:41.517934 IP 200.200.200.101.88 > 200.200.200.10.47126: S 3205360631:3205360631(0) ack 1242901182 win 5792 00:27:41.517946 IP 200.200.200.10.47126 > 200.200.200.101.88: . ack 1 win 4380 00:27:41.517957 IP 200.200.200.10.47126 > 200.200.200.101.88: P 1:155(154) ack 1 win 4380 00:27:41.518888 IP 200.200.200.101.88 > 200.200.200.10.47126: . ack 155 win 54 00:27:41.522163 IP 200.200.200.10.47126 > 200.200.200.101.88: F 155:155(0) ack 1 win 4380 00:27:41.522884 IP 200.200.200.101.88 > 200.200.200.10.47126: F 1:1(0) ack 156 win 54 00:27:41.522899 IP 200.200.200.10.47126 > 200.200.200.101.88: . ack 2 win 4380 00:27:41.617423 IP 172.28.19.79.80 > 172.28.19.253.47126: . ack 155 win 4534 - hoolio
Maybe we could use HTTP::retry instead of LB::reselect?
Aaron - nitass
Employee
HTTP::retry is not valid in LB_SELECTED event.
Please feel free to let me know if you would like to try any other command. - Roman_80473
Aaron and nitass,
Thank you for your replies. I still think I don't quite get it. I set the monitor_id with "after" inside LB_SELECTED, then cancel it in both http_request and http_response. That works and I don't get stuck in lb_selected anymore. But, the same story now happens in http_request, where I get in, but never exit. I set the monitor at the end of http_request the same way, and I do trap the timeout when server is not responding. However, I also trap timeout even if nothing's wrong. Am I missing smth?
Thanks, Roman - nitass
Employee
I set the monitor_id with "after" inside LB_SELECTED, then cancel it in both http_request and http_response.i do not think we should cancel monitor_id in HTTP_REQUEST event since the monitor_id will start scheduling in LB_SELECTED event.
the situation Aaron and I am discussing is when bigip has established 3-ways handshake to pool member and that is it (the pool member does not respond to GET request). what we want to do is to re-select another pool or pool member, establish a new 3-ways handshake and send GET request over. however, it appears bigip does not pick up a new pool or pool member. - hoolio
Nitass, can you try putting the after statement in HTTP_REQUEST and use (LB::detach + LB::reselect) or HTTP::retry? Else, I can try testing this later today.
Aaron
