Deployment Guide for Blackboard and BigIP LTM?
Since I had such luck with my first posting, I'll try again. Is there a deployment guide for using Blackboard v7 on IIS6 with F5 LTM? Blackboards "selective" SSL settings are giving me fits. I'm wondering if I'll have to put certs on my webservers (nodes) as well as a cert on the F5 to get https that doesn't loop but gets balanced. Again, any help will be appreciated.
- JG
Cumulonimbus
It's basically just the Apache HTTP server, plus Tomcat, so it's fairly easy to get it work with some basic configurations. See http://www.f5.com/pdf/deployment-guides/f5-apache-dg.pdf . For auxiliary services, a virtual server with a simple TCP or "Performance (Layer 4)" type will work.
- latheef_53585
I'm looking for a document which can guide me to configure Blackboard 9.1 SP13 on F5 OS 10.0.0. Please share the document.
My mail ID is [email protected]
Thanks in advance.
a.latheef
- Gavin_Connell-O
My bad, it was Safari that started causing our connection overload, and this was quite a way back. So far no issues with FF 27 (so far...) Our solution was to create an iRule which intercepted preview requests and sent a thumbnail jpg instead of polling the BB server. The JPG was stored as an iFile on the F5...
Probably not your issue, but it's good to share! :)
Gavin
- Gavin_Connell-O
Hi dlegate, I've got Nick's original integration doc in PDF. Send me your email address and I'll pass it over.
As for your increase of connections coming from firefox, I think we had a similar problem with chrome whereby the new tab preview page was polling all recently used pages whenever a user would open a new tab. It was creating a situation not dissimilar from what you describe. I'll double-check my records and post again soon.
Gavin
- dlegate_23320
Sigh... looks like Nick's document is now password protected? I know it's probably outdated, but still, would be nice to see for reference.
I just recently opened a ticket with Blackboard asking about Firefox 27 opening thousands of connections suddenly and since our homepage with Community creates a session for each "user" and these (presumably prefetch) connections don't store cookies, each connection gets its own session, killing our database performance if it lasts more than 10-20 minutes.
Blackboard sent me their NetScaler scripts used in Managed Hosting. I don't know if anyone at DevCentral would be able to look at those and "translate" them to F5 iRules, but they seem to be tried-and-true since managed hosting currently hosts about 60% of Blackboard customers.
Here's then information in the ticket:
[---- begin ticket response ----
For the, Limit Selector- "Each selectlet is a non-compound advanced expression, and is a "AND" relationship with others". For the "Limit Identifier, 'the threshold is set to a value of "2" to allow double click on a link. Default value for time slice is 1000ms(1s), it is enough for a normal browse operation. Means at most click a URL twice within one second.'
These are example URIs being excluded:
- /bbcswebdav/pid-2578707-dt-content-rid-6462928_1/xid-6462928_1
- /webapps/login?new_loc=%2Fmodules%2F_142_1%2Fearh.jpg
- /webapps/login/
- /bbcswebdav/pid-394082-dt-content-rid-1439038_1/courses/10046.201305.XLIST/section6_3%20Filled.pdf
- /webapps/blackboard/content/FirstFrame.png
- /webapps/vtbe-tinymce/tiny_mce/plugins/spellchecker/css/content.css
- /webapps/sen-coursesplus-bb_bb60//images/empty.gif
- /webapps/sen-coursesplus-bb_bb60//images/announcement.png
- /apple-touch-icon-precomposed.png
- /sessions/5/1/8/4/6/9/3/session/gradebook_20130510910.201305_Assignment20_5_2013-06-15-08-20-10.zip
- /@@/CFAA8BD48A1E2FD9DD2E9C1DF26412C5/courses/1/MHRC433-A335_2137_DD/db/_23966706_1/MHRC%202.2.mov
Some of these are standard others not, of course those that are non-standard had to be identified through analysis.
---- end ticket response ----]
If anyone knows how to translate NetScaler scripting to F5, I'd be happy to send the actual script as well.
Dan
- Gavin_Connell-O
Happy to share our design, but I may need to go through it and redact certain bits, just for confidentiality reasons :)
- Gavin_Connell-O
We load balance Blackboard with Big-IP 11.2.1 HF6, and we've had no real problems. We based our design around our previous Cisco Content Switch configuration, and Nick McClure's guide (thanks Nick!).
If anyone needs help with a particular aspect of the setup, let me know and we can collaborate.
Cheers - Gavin Connell-Otten Victoria University Wellington (NZ)
- JG
Cumulonimbus
If you have to use a stream profile to get the app to work, that means the app is not designed to work with F5 out-of-box. For us, it has worked well with SSL bridging. Don't use ramcache unless you know what you are doing, and do not use compression as there is currently an unresolved security issue with it.
We do have a http->https redirect set up as well.
- cwtang_18682
Thought to ask if anyone may have an updated copy of the deployment guide that may be shared?
- is there an up to date guide around somewhere?
