lingesh_118835's avatar
lingesh_118835
11 years ago
Delete Persistence records for a node in LTM
How we can delete Persistence records for a node
ex : I am going to delete members in a pool.
How to remove persistence records for the existing nodes.
  • In v11, you can use the show command in tmsh to find the records, ensuring they're the correct ones, then change 'show' to 'delete':
    show ltm persistence persist-records node-addr 1.2.3.4
    Then:
    delete ltm persistence persist-records node-addr 1.2.3.4
    If you delete members from the pool, surviving members will be chosen for load balancing even if there is persistence to the DOWN members.
    • Wasfi_182818's avatar
      Wasfi_182818
      Can the deleting of persistence records be done at the pool member granularity too?
      Kindly Wasfi
    • KeesvandenBos's avatar
      KeesvandenBos
      Icon for MVP rankMVP
      Hi Wasfi,
      show ltm persistence persist-records pool
      delete ltm persistence persist-records pool node-addr 1.2.3.4
      or
      delete ltm persistence persist-records pool client-addr 5.6.7.8
      Cheers,
      Kees
