Luca_55898
Sep 01, 2011Default HTTP monitor
I have a pool of servers assiged to a VIP.
The VIP listens on 7800 and forwards to the nodes in the pool on 7800 as well
I just need to do a simple http monitor, was just wondering if the default http monitor will work over these non-standard ports, or will i need to do a custom monitor to check a http connection over port 7800?
thanks
- nitass
Employee
default http monitor could work fine.
btw, make sure u use the correct send string syntax.
sol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
http://support.f5.com/kb/en-us/solu...l2167.html
