Debugging Flow Messages through MBLB
Hi all,
Using a virtual Server with MBLB Profile, the LTM knows internally how to deliver a TCP message from a client based on TCP connections . So, Is there a way to debug these events using irules?
Tks
- nitass
Employee
just wondering if putting log in irule event is not helpful.
- Colin_Walker_12Historic F5 Account
When you say "Debug these events", what data is it you're trying to obtain, exactly? As nitass said above, a log statement will likely net you some info, but it depends largely on what you're looking for specifically.
Colin - robson_78577
Hi guys,
I need data information about how LTM deliver the message and how to correlate with the TCP connection. Considerong MBLB IS message-based oriented, how it works?
I'm working on a irule and using MBLB, but its impossible use some commands on events, like TCP::local_port on SERVER_DATA. Some commands works well when IRemove the MBLB, but I need to use it.
So I need a way to identify and debug message flow.
Tks in advance
- nitass
Employee
doesn't TCP::local_port in SERVER_DATA work?
this is mine.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.20.111:7 ip-protocol tcp mask 255.255.255.255 pool foo profiles { mblb { } tcp { } } rules { myrule } source 0.0.0.0/0 source-address-translation { type automap } vs-index 23 } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:7 { address 200.200.200.101 } 200.200.200.111:7 { address 200.200.200.111 } } } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when CLIENT_ACCEPTED { TCP::collect } when CLIENT_DATA { log local0. "[IP::remote_addr][TCP::remote_port] > [IP::local_addr]:[TCP::local_port] payload=[TCP::payload]" TCP::release TCP::notify request TCP::collect } when SERVER_CONNECTED { TCP::collect } when SERVER_DATA { log local0. "[IP::local_addr]:[TCP::local_port] > [IP::remote_addr]:[TCP::remote_port] payload=[TCP::payload]" TCP::release TCP::notify response TCP::collect } [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Aug 31 13:40:33 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=1 Aug 31 13:40:33 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.111:7 payload=1 Aug 31 13:40:34 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=2 Aug 31 13:40:34 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.101:7 payload=2 Aug 31 13:40:35 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=3 Aug 31 13:40:35 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.111:7 payload=3 Aug 31 13:40:36 ve11a info tmm[1027]: Rule /Common/myrule : 172.28.20.1759863 > 172.28.20.111:7 payload=4 Aug 31 13:40:36 ve11a info tmm[1027]: Rule /Common/myrule : 200.200.200.14:59863 > 200.200.200.101:7 payload=4 - robson_78577
Hi Nitaas,
Yes, it's working. But just when I remove MBLB profile. But I will do some tests on Monday, and I will post my Irule.
Tks in advance.
