Custom cipher suite
Can you help me set it up on an F5 running 12.1.2 HF1. I am following the cipher suite that is stated on this guide.
Here's the one I would like to use
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 TLS_DHE_RSA_WITH_AES_128_CBC_SHA TLS_DHE_RSA_WITH_AES_256_CBC_SHA TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
The DEFAULT cipher suite shows weak cipher suites.
- BAMcHenryRet. Employee
Have you reviewed the SSL Everywhere Recommended Practices Guide? https://f5.com/Portals/1/Premium/Architectures/RA-SSL-Everywhere-deployment-guide.pdf
- edmonaft_351139
I've reviewed it. Just want to confirm validity of this document vs the current SSL recommendations as it was still published last 2015.
The SSL Labs list of ciphers to include and the order of priority is certainly the most accurate and updated.
DEFAULT is set to the best balance of security and performance at the time of a given release. DEFAULT is updated with each release of TMOS. The Recommended Practices Guide covers how to customize the cipher string to meet updated standards as indicated by SSL Labs or other standards-setting bodies.
Please check the section "Fine-Tuning Data Protection" starting on page 8 on how to build a cipher string to create the list of ciphers in your original post.
- edmonaft_351139
Based of the instruction, I see that it requires me to access F5 via SSH to enter this commands. I wonder if there's a way to do it via GUI? I am not too comfortable doing this via SSH.
- nathe
Cirrocumulus
The only reason you would need the CLI is to perform the
command to detail what ciphers a string will create.tmm --clientciphersHow about this one? You then just need to add this to the cipher string in the clientssl profile
tmm --clientciphers 'ECDHE_ECDSA:ECDHE+AES-GCM:ECDHE+AES:ECDHE+3DES:DHE+AES-GCM:DHE+AES:DHE+3DES:RSA+AESGCM:-MD5:-SSLv3:-RC4:-3DES' ID SUITE BITS PROT METHOD CIPHER MAC KEYX 0: 49196 ECDHE-ECDSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_ECDSA 1: 49188 ECDHE-ECDSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_ECDSA 2: 49162 ECDHE-ECDSA-AES256-SHA 256 TLS1 Native AES SHA ECDHE_ECDSA 3: 49162 ECDHE-ECDSA-AES256-SHA 256 TLS1.1 Native AES SHA ECDHE_ECDSA 4: 49162 ECDHE-ECDSA-AES256-SHA 256 TLS1.2 Native AES SHA ECDHE_ECDSA 5: 49195 ECDHE-ECDSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_ECDSA 6: 49187 ECDHE-ECDSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_ECDSA 7: 49161 ECDHE-ECDSA-AES128-SHA 128 TLS1 Native AES SHA ECDHE_ECDSA 8: 49161 ECDHE-ECDSA-AES128-SHA 128 TLS1.1 Native AES SHA ECDHE_ECDSA 9: 49161 ECDHE-ECDSA-AES128-SHA 128 TLS1.2 Native AES SHA ECDHE_ECDSA 10: 49200 ECDHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_RSA 11: 49199 ECDHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_RSA 12: 49192 ECDHE-RSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_RSA 13: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1 Native AES SHA ECDHE_RSA 14: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.1 Native AES SHA ECDHE_RSA 15: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.2 Native AES SHA ECDHE_RSA 16: 49191 ECDHE-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_RSA 17: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1 Native AES SHA ECDHE_RSA 18: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.1 Native AES SHA ECDHE_RSA 19: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.2 Native AES SHA ECDHE_RSA 20: 159 DHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 EDH/RSA 21: 158 DHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 EDH/RSA 22: 107 DHE-RSA-AES256-SHA256 256 TLS1.2 Native AES SHA256 EDH/RSA 23: 57 DHE-RSA-AES256-SHA 256 TLS1 Native AES SHA EDH/RSA 24: 57 DHE-RSA-AES256-SHA 256 TLS1.1 Native AES SHA EDH/RSA 25: 57 DHE-RSA-AES256-SHA 256 TLS1.2 Native AES SHA EDH/RSA 26: 57 DHE-RSA-AES256-SHA 256 DTLS1 Native AES SHA EDH/RSA 27: 103 DHE-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 EDH/RSA 28: 51 DHE-RSA-AES128-SHA 128 TLS1 Native AES SHA EDH/RSA 29: 51 DHE-RSA-AES128-SHA 128 TLS1.1 Native AES SHA EDH/RSA 30: 51 DHE-RSA-AES128-SHA 128 TLS1.2 Native AES SHA EDH/RSA 31: 51 DHE-RSA-AES128-SHA 128 DTLS1 Native AES SHA EDH/RSABy the way, you didn't specify TLS version so this includes all TLS versions. If you add -TLSv1 at the end that would disallow TLS 1.0
Rgds N
