epaalx's avatar
epaalx
Icon for Cirrus rankCirrus
Aug 18, 2011
Creating local users when using Remote Authentication
Hi F5'ers,
I'd like to provision (some) local users even though Remote Authentication (using Radius) is provisioned.
F5 removed f5adduser (in 10.1.0), so, what's the sanctioned alternative?
R's, Alex.
  • /etc/cron.hourly/localUserInsert
    #!/bin/bash
    grep myUser /config/bigip/auth/localusers
    if [ $? -eq 1 ]; then
    	echo myUser >> /config/bigip/auth/localusers
    fi
    And i'll probably need to recreate it after every upgrade, but that's not a big deal.
  • Willy's avatar
    Willy
    Thank you jaikumar_f5 and Dojs for your advice and effort. I will go for the update to a version above 12, it is than a standard feature.
  • Dojs's avatar
    Dojs
    Remove the Radius Authentication, create the users and config it again.
  • Willy's avatar
    Willy
    Hello eaa,
    Tried to modify the database parameter, and succeeded, but stil not able to create a local user. When I tried to create a user via cli, and then change the password, I still get the answer "Please change the password at the remote authentication server". Also in the GUI there is no extra trace of a field that suggest a local user fallback. Maybe it is easier to plan a migration to version 13.
  • Willy's avatar
    Willy
    Hello,
    I have been looking for the Fallback to Local, in the above screen :
    Is it possible that this option is not available in 12.1.3.7 ?
  • Willy's avatar
    Willy
    I am a bit confused now,in the top rectangle it is mentioned "can't be done".
    The next rectangle provides a command for doing it ?
    At this moment we are using version 12.1.3.7. Is there any change ?
    We would like to use one extra local user on top of the remote users , to run a script for automated backup with keys.
    Point is that we would like to take the server the initiative for the actions.
    Anyone a suggestion ?
    • Hi Willy,
      • Enable "Fallback to Local" (System » Users » Authentication)
      • Create a user (System » Users » User List)
      • Run the below command:
      echo "username" >> /config/bigip/auth/localusers
      sed -ri 's/(localonlyusers LT_STRING_LIST.*)"/\1 \\{username\\}"/' /etc/confpp.dat
      • jaikumar_f5's avatar
        jaikumar_f5
        Icon for Noctilucent rankNoctilucent
        That is the behavior of the box. Please refer the article K11333640.
        To overcome this, you'll have to create a startup script. Which would be on /config/startup.
        Did you put the entries there & yet you see this issue ?
        Also note this is pretty 10 year old thread, please open a new thread so it could be addressed properly.
  • "TMOS Management Guide for BIG-IP Systems" says: "Excluding the admin account, the entire set of standard user accounts that you create for BIG-IP system administrators must reside either locally on the BIG-IP system, or remotely on another type of authentication server."
    So, answer is - it can't be done.
  • tmsh create /auth user role shell partition-access encrypted-password|password|prompt-for-password
