Ivan_Garcia_381
May 31, 2012Create Volume HD1.2 -Deleted accidentally-
Hi there,
I'd like you say to me how could I re-create the volume HD1.2 that I've delete accidentally, It's possible to do this, I don't find the procedure in the manual.
I've BIGIP-VE 11.1.x
Thanks a lot of.
- hoolio
Hi Ivan,
You can install a new operating system instance for a slot, but there isn't a way to recover the original one. To do this, navigate to:
System | Software Management
Click on the OS version you want to install
Select the slot you want to install the OS on and click Install
Aaron - Techgeeeg
Hi Ivan,
If I am not wrong what you are trying to ask is that how can you create the volume and you are running version 11.1.... In version 10.x.x there was a tab in GUI for Volume management which is missing in Version 11.1 so the only way you may create the new volume is from the command line or If you still have a ver 10.x.x running in any of the volume you may boot into it and create the volume from command line.
Regards, - Techgeeeg
Hi Ivan,
I believe below link is the answer of ur query
https://support.f5.com/kb/en-us/solutions/public/13000/500/sol13563.html?sr=21614094
Regards, - Microgag_61404
tmsh install sys software images xx.iso create-volume volume HD1.2
- Mike_Dayton_108
image not images Thanks, worked like a charm for 11.5.3
