Could someone help me with a simple redirect (iRule)?
Sorry if any of this is dumb new user stuff... I have done a bit of searching and can't find a clear answer.
Basically what I want to do is have anyone hitting "www.mypage.com/something" redirect to just "www.mypage.com"
We have some tools and services in the /something page that should not be available to the public, and until we find a better way, we want to just redirect to the root of the site. It also needs to work with https requests too.
I don't have very much experience with F5s so be gentle!
Here is what I have come up with so far:
when HTTP_REQUEST { if { [HTTP::path] equals "/admin" } { HTTP::redirect "/" } }
Any suggestions?
Thanks!
You might consider using a Traffic policy (if you are on TMOS 11.4 or greater) 2 Minute Tech Tip: URL Redirects
If not then you might want to consider an iRule something like this:
when HTTP_REQUEST { if { [string tolower [HTTP::path]] starts_with "/admin" } { HTTP::redirect "/" } }Either way you will have to apply the traffic policy to the HTTP and HTTPS virtual server.
- Max_Q_factor
Cirrocumulus
- metalslug2004_2
Looks like I'm on 10.0.1.... =(
But I will give that iRule you posted a try!
Thank you very much.
- metalslug2004_2
Another newb question. So that iRule is applied globally correct? Once i make that rule, it should take affect immediately?
Also, that rule should work for both HTTP and HTTPS correct?
Thanks,
- Max_Q_factor
Cirrocumulus
Yes. iRules take effect immediatly. Also since you are using a relative redirect the iRule should work for both http and https as long as the virtual server has a http profile and the https virtual server is decrypting the client side. - metalslug2004_2
Again, thank you very much for your help!
