Sharank's avatar
Sharank
Dec 19, 2017
Cookie encryption and RAW data required
Dear all,
Have a query on cookie
What is the Recommended Industrial best practise for cookie encryption
One of our customer needs cookie encryption enabled.. at the same time... Part of of cookies should be available RAW for his application to work..
Need your suggestions/ideas to take this forward
  • question is whether there is anything sensitive within the cookie, why you need to encrypt cookie? using https against mitm isn't enough? is client storing this cookie for a longer period and you expect someone will access it, tamper it, etc...?
    for the best practices:
    • limit the amount of sensitive information stored in the cookie.
    • limit the subdomains and paths to prevent interception by another application.
    • enforce SSL so the cookie isn’t sent in cleartext.
    • make the cookie HttpOnly
    perhaps you can read more at https://www.owasp.org/index.php/Session_Management_Cheat_SheetCookies
