sgoodliff_83611's avatar
sgoodliff_83611
Jan 18, 2008
cookie based connection limits
Hello,
I've been playing with this irule which is meant to set a cookie per client. But I'm using firefox and it sets 4 cookies. one per http request, Is there any way for it to be a bit cleverer and only set one cookie per client. I was thinking about checking if it is a keep alive request and seeing if that helped.
Any suggestions ?
http://devcentral.f5.com/wiki/default.aspx/iRules/HTTPSessionLimit.html
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    You might try making a small addition to the HTTP_RESPONSE stanza.
      when HTTP_RESPONSE {
       ; insert cookie if needed
       if {$need_cookie == 1} {
         HTTP::cookie insert name "ClientID" value $client_id
         set need_cookie 0
    This is the only way I can really think that there would be multiple cookies inserted. The code looks good other than that.
    Colin
  • Hello,
    I've got it sorted.
    swap:
    For this:
    HTTP::cookie insert name "ClientID" value $client_id path "/"
    And now it works much better.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Excellent catch, I've updated the codeshare sample.
    thanks!
    /deb
  • hoolio's avatar
    hoolio
    Out of curiosity, why would setting the path to / make a difference? I would have assumed that if the path is not set it would default to any path (ie, /).
    Aaron
