Michael_Hull_61's avatar
Michael_Hull_61
Dec 21, 2005
Connection verification to another pool
Pools are named Pool_1 and Pool_2 and exist on the same BigIP pair.
I want to know if an iRule can only allow a connection to Pool_2 if you already have a current connection to Pool_1?
Scenario 1:
A web client establishes a connection to a virtual tied to Pool_1.
From same host, opens up another web client and connects to another virtual tied to Pool_2. In this case, the connection to Pool_2 is successful because the host has already established a connection to Pool_1.
Scenario 2:
A web client tries to establish a connection to a virtual tied to Pool_2. The BigIP determines there is no connection already established with Pool_1 and drops/redirects the connection.
  • You should be able to populate a global array with client IP address when connected to Pool_1, then check the array when clients attempt connection on other vs with Pool_2, and discard if client IP is not in the array. This should get you started. You'll probably want to add some error checking and a method to clean up the array.
     virtual server 1 iRule (pool 1)
    when CLIENT_ACCEPTED {
       populate array with client IP address
      set ::pool1_clients([IP::client_addr])
      use pool 1
     virtual server 2 iRule (pool 2)
       if { [info exists $::pool1_clients([IP::client_addr])] } {
         use pool 2
       } else { redirect "http://" }
  • Thank you very much for your quick response!! I will get with the application owners to see when we can test these rules.
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    You should probably do this with the session table instead (using the "session add" and "session lookup" commands). The session table has a timeout associated with the entries, so you don't need to worry about eventually using up all the memory on your box since nothing removes entries from the global array.
    unRuleY_95363
    Historic F5 Account
    Try this rule:
        populate session table with client IP address for 1 hour
       session add source_addr [IP::client_addr] 1 3600
       use pool 1
       if { [session lookup source_addr [IP::client_addr]] } {
          use pool 2
          redirect "http://"
    Note each session lookup refreshes the TTL on a session table entry, so as long as subsequent requests occur within an hour, the entry will remain active.
