brianokelly_119's avatar
brianokelly_119
Aug 14, 2011
Connection Statistics
We are looking to gather statistics on pool/virtual server usage similar to what is seen from the statistics dashboard but we wish to do this without the use of SNMP. Is it possible to output the statistics into a text file on the F5 periodically? My initial idea is to output this information into a log file from an iRule (pool memeber used, src ip, dst ip, etc).
  • Kevin is correct about versions through v10. In v11, however, there will be capability to track object-related stats in iRules and share stats between iRules and tmsh. I'll get the documentation up when the bits for v11 hit the download site, which should occur in the near future.
