mg2Bsecure's avatar
mg2Bsecure
Dec 11, 2019
Connection Limit iRule vs Pool member connection limit
for some reason a pool member connection limit (set to 1) still lets another user connect to RDP. Only when an iRule is applied, it drops additional connections.
Can someone help?
the Rule follows:
when RULE_INIT {
  set ::active_connections 0
  set ::max_connections 1
when CLIENT_ACCEPTED {
  if {$::active_connections > $::max_connections } {
   set over_limit 1
   incr ::active_connections 1
when USER_REQUEST {
  if {$over_limit}{
   TCP::respond "connection busy command\r\n"
   TCP::close
when CLIENT_CLOSED {
  incr ::active_connections -1
