Gurpreet_40964
Mar 01, 2012Connecting to F5 i control API through JAVA code
I am getting error while connecting to F5 device. I guess probable reason is certificate (Caused by: java.lang.Exception: Truststore file does not exist:). Can anybody help me... how can i get this certificate...
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: java.net.SocketException: java.security.NoSuchAlgorithmException: SSLContext Default implementation not found:
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:java.net.SocketException: java.security.NoSuchAlgorithmException: SSLContext Default implementation not found:
at javax.net.ssl.DefaultSSLSocketFactory.a(SSLSocketFactory.java:7)
at javax.net.ssl.DefaultSSLSocketFactory.createSocket(SSLSocketFactory.java:11)
at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:92)
at org.apache.axis.transport.http.HTTPSender.getSocket(HTTPSender.java:191)
at org.apache.axis.transport.http.HTTPSender.writeToSocket(HTTPSender.java:404)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:138)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:165)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at iControl.SystemFailoverBindingStub.get_failover_state(SystemFailoverBindingStub.java:274)
at f5Admin.F5Admin.connectToF5(F5Admin.java:419)
at f5Admin.F5Admin.main(F5Admin.java:1343)
Caused by: java.security.NoSuchAlgorithmException: SSLContext Default implementation not found:
at java.security.Provider$Service.newInstance(Provider.java:889)
at sun.security.jca.GetInstance.getInstance(GetInstance.java:299)
at sun.security.jca.GetInstance.getInstance(GetInstance.java:237)
at javax.net.ssl.SSLContext.getInstance(SSLContext.java:25)
at javax.net.ssl.SSLContext.getDefault(SSLContext.java:15)
at javax.net.ssl.SSLSocketFactory.getDefault(SSLSocketFactory.java:17)
at org.apache.axis.components.net.JSSESocketFactory.initFactory(JSSESocketFactory.java:61)
at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:79)
... 15 more
Caused by: java.lang.Exception: Truststore file does not exist: C:\Documents and Settings\gxsing\.keystore
at com.ibm.jsse2.tc.a(tc.java:59)
at com.ibm.jsse2.kc.f(kc.java:19)
at com.ibm.jsse2.kc.(kc.java:16)
at java.lang.J9VMInternals.newInstanceImpl(Native Method)
at java.lang.Class.newInstance(Class.java:1325)
at java.security.Provider$Service.newInstance(Provider.java:875)
... 22 more
{http://xml.apache.org/axis/}hostname:PHXJ04968711
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:154)
Caused by: java.net.SocketException: java.security.NoSuchAlgorithmException: SSLContext Default implementation not found:
... 12 more
... 15 more
Caused by: java.lang.Exception: Truststore file does not exist: C:\Documents and Settings\user1\.keystore
... 22 more
Mar 1, 2012 11:15:51 AM F5Admin connectToF5
SEVERE: ERROR: Could not connect to F5java.net.SocketException: java.security.NoSuchAlgorithmException: SSLContext Default implementation not found:
Mar 1, 2012 11:15:51 AM F5Admin Main
SEVERE: Failed to connect to F5
Mar 1, 2012 11:15:51 AM F5Admin exitF5Admin
- Are you using the iControl library for Java that I built?
https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/2/Default.aspx
If not, what library are you using?
I ran into the truststore issue due to the self-signed certs that the BIG-IP uses. I implemented a trust provider in that library that I documented in this blog post:
https://devcentral.f5.com/weblogs/joe/archive/2005/07/06/1345.aspx
Hope this gives you enough to get you going. If you aren't using my library, I'd love to hear what other Java toolkit you are using.
-Joe - Gurpreet_40964
Hi Joe,
Thanks for the reply. Sorry i was not able to reply for some time. So i used your Xtrust install class. But it seems that i already have provider : 'XTrustJSSE version 1.0'.
I used this code:
public static void install()
java.security.Provider name = Security.getProvider(NAME);
int flag = 0;
if(Security.getProvider(NAME) == null)
flag=1;
Security.insertProviderAt(new XTrustProvider(), 2);
Security.setProperty("ssl.TrustManagerFactory.algorithm",
TrustManagerFactoryImpl.getAlgorithm());
if(flag==0){
System.out.println("Not installed");
System.out.println("Security Provider is : "+name);
Output is :
Not installed
Security Provider is : XTrustJSSE version 1.0 - Hasan_35483
How did you solve your problem ?
I face the following error. Any ideas ?
AxisFault
faultSubcode:
faultString: java.net.SocketException: java.lang.ClassNotFoundException: Cannot find the specified class com.ibm.websphere.ssl.protocol.SSLSocketFactory
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:java.net.SocketException: java.lang.ClassNotFoundException: Cannot find the specified class com.ibm.websphere.ssl.protocol.SSLSocketFactory
at iControl.LocalLBPoolBindingStub.get_list(LocalLBPoolBindingStub.java:1533)
at bigIPF5LoadBalancer.LoadBalancerPolicy.createPool(LoadBalancerPolicy.java:94)
at bigIPF5LoadBalancer.Test.main(Test.java:69)
Caused by: java.lang.ClassNotFoundException: Cannot find the specified class com.ibm.websphere.ssl.protocol.SSLSocketFactory
at javax.net.ssl.SSLJsseUtil.b(SSLJsseUtil.java:20)
at javax.net.ssl.SSLSocketFactory.getDefault(SSLSocketFactory.java:36)
... 15 more
{http://xml.apache.org/axis/}hostname:tpmoutbound9
Caused by: java.net.SocketException: java.lang.ClassNotFoundException: Cannot find the specified class com.ibm.websphere.ssl.protocol.SSLSocketFactory
... 12 more
... 15 more - Hasan_35483
I added the following line of code to get rid of the above error ; but now i face the trustore file missing problem :. I am using iControl Assembly 10.2 Java
Security.setProperty("ssl.SocketFactory.provider", "com.ibm.jsse2.SSLSocketFactoryImpl");
AxisFault
faultSubcode:
faultString: java.net.SocketException: java.lang.Exception: Truststore file does not exist: C:\Users\Administrator\.keystore
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:java.net.SocketException: java.lang.Exception: Truststore file does not exist: C:\Users\Administrator\.keystore
at bigIPF5LoadBalancer.LoadBalancerPolicy.createPool(LoadBalancerPolicy.java:102)
Caused by: java.lang.Exception: Truststore file does not exist: C:\Users\Administrator\.keystore
at com.ibm.jsse2.tc.a(tc.java:55)
at com.ibm.jsse2.kc.f(kc.java:14)
at com.ibm.jsse2.kc.(kc.java:23)
at com.ibm.jsse2.kc.e(kc.java:8)
at com.ibm.jsse2.SSLSocketFactoryImpl.(SSLSocketFactoryImpl.java:5)
at java.lang.Class.newInstance(Class.java:1328)
at javax.net.ssl.SSLSocketFactory.getDefault(SSLSocketFactory.java:21)
... 15 more
Caused by: java.net.SocketException: java.lang.Exception: Truststore file does not exist: C:\Users\Administrator\.keystore
... 12 more
... 15 more - Gurpreet_40964
We were able to solve this problem by having jks keystore setup in our websphere servers. alternate is use signer certificates in websphere. In local you can add certificates manually.
