Configuring wide ip in Link Controller
Hi everybody !
I hope someone can help me with this, I'm trying to configure an inbound load balance with the link controller module, so for this I need to set up a wide ip, I been following the steps to create it but when it comes to associate the wide ip to a virtual server, there's simple no option available in the field "virtual server". I've already created a listener and a virtual server that would be responding for this wide ip, but this option does not appear in the fall down menu within the wide ip sub menu.
Hope someone can help me,
Thanks !!
- El_Jefe
Eduardo,
You have to configure the GTM for datacenters, and add the LC. Then, either manually add the virtual, or auto discover it. You can then assign a pool to the wide-ip, and add the virtual to it. Hope this helps.
Jeff
