Fabrizio_Chiava's avatar
Fabrizio_Chiava
May 21, 2010
configuring trunk with Cisco Nexus 7000
Hello everybody,
I need help to an issue.... I’ve a network problem about Viprion and Trunks. I configured a Trunk between a Cisco Nexus 7000 and a BIGIP Viprion with Blade 100:
Trunk Viprion config
Link Selection Policy Auto
Frame distribution hash Source/Destination MAC address
Cisco Nexus 7000 (Port Channel)
interface port-channel50
description Viprion-F5-Bil
shutdown
switchport
switchport mode trunk
switchport trunk allowed vlan 310,330,610,630
sh port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-dest-ip-vlan
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-ip-vlan
interface Ethernet1/25
description Viprion
switchport
channel-group 50
no shutdown
The interface port-channel50 is in shutdown because it’s in a working mode and customer don’t want to configuring anything, it’s a critical environment..
So, we tested the network traffic, the trunk on Viprion goes UP and (from Nexus to Viprion) if I try to ping the self IP, it’s working, I can’t do the revert operation and I can’s see the server on server farm.
Now I would to understand if I need to setting only a LACP trunk, or it’s possible to configure in another way?
What’s happen on the Viprion if I configure a NO LACP Trunk? And what does happened with LACP trunk?
Could you help me for this?
Please tell me if you need something else.
Thanks a lot
Best Regards
Fabrizio.
