ClaudeM_303043's avatar
ClaudeM_303043
Jul 18, 2017
Configuring custom health check (send string)
I need to configure custom health monitors (http & https) and I'm stuck at configuring the Send string. I have it configured to go to and receive "yes".
When I configured the Send string I used the following which isn't working; GET /sso.companyname/sortingpen/sortingpen.aspx\r\n
I've tried multiple variations and nothing is working.
Thanks in advance for your help!!
  • Try
    GET /sortingpen/sortingpen.aspx\r\n\r\n
    as long as the pool member(s) accept the HTTP/0.9 protocol level.
    Article K2167 has further details on constructing well-formed SEND strings.
  • P_K's avatar
    P_K
    did you try this?
    GET /sortingpen/sortingpen.aspx HTTP/1.1\r\nHost: sso.companyname.com\r\nConnection: Close\r\n
