Configuring Complex Load Balancing Scenario
Hello.
I'm trying to configure a virtual server using an especial load balancing scenario which is driving me crazy.
Specification:
- 2 clusters with 2 nodes each one.
- each cluster will be served as active-passive method.
- each node in the cluster will be served as round robin.
- when a cluster changes to active, it will keep this status although the initial active cluster change back to up status.
- each cluster will be served as active-passive method -> solved using priority groups
- each node in the cluster will be served as round robin -> solved using a RR method in the pool
- when a cluster changes to active, it will keep this status although the initial active cluster change back to up status -> PROBLEM! I would use persistence, but I have two nodes instead of one :-(
I need to configure this using just a single F5.
Any help will be appreciated.
KR, Dario
- Ryannnnnnnnn
Altocumulus
Are you saying that for example, you want cluster B to remain active even though cluster A may come back "up"?
If that's the case then i would do something like assign health monitors at a pool member level and i would configure the monitors that get assigned to the members in cluster A so that manual resume is enabled, that way you can return cluster A to being active when you desire.
Or i could have totally misunderstood your requirements :)
- DarioGB_339840
Altostratus
Actually, I was taking in consideration to use "Manual Resume", but the point here is that both members of the cluster should work as a single node.
Imagine this scenario from the picture above.
Cluster-A, Node 1 - Passive Cluster-A, Node 2 - Passive Cluster-B, Node 3 - Active Cluster-B, Node 4 - ActiveIn case of node 4 flapping (down-up), it should be automatically re-enable to help Node 3 to serve the traffic.
If both nodes (3 and 4) would be down at the same time, then the cluster should change from Active to passive:
Cluster-A, Node 1 - Active Cluster-A, Node 2 - Active Cluster-B, Node 3 - Passive Cluster-B, Node 4 - PassiveI guess I cannot get exactly this behaviour using "Manual Resume"...
KR, Dario
- Ryan_80361
- DarioGB_339840
Altostratus
KR, Dario
- Dario_Garrido
Noctilucent
Finally, this is the solution adopted -> https://devcentral.f5.com/codeshare/especial-load-balancing-active-pasive-scenario-1199
