ESDRAS_368680's avatar
ESDRAS_368680
7 years ago
configure f5 big ip in front of cisco asa
i have node (servers) behind a cisco asa and these servers are reachable from cisco ASA outside interface by ACL and NAT and PAT. i have a f5 big ip asm configured and face to internet. the f5 internal and asa outside interface are in the same network. i create node whitch is the cisco asa outside interface And pool on a a specific port on that node (asa outside)
i need to create a vs so that all requests from internet be redirected to cisco asa (outside) on a specific port which will redirect the flow to my servers connected to the cisco asa inside. can you help me please ?
  • I would create a pool with the nodes (servers) ip's behind the ASA. The ASA is not a load balancer so it won't balance the traffic.
    Cheers,
    Kees
  • hello thanks for your reply. my configuration is the following : asa inside 10.100.72.4 asa outside 10.100.251.81 asa gateway f5 internal : 10.100.251.85
    f5 internal : 10.100.251.85 f5 external : 41.x.x.x f5 gateway : isp
    my servers are connected to asa inside : server 1 : 10.100.72.8 server 2 : 10.100.72.10
    i have configured NAT and PAT on port 10444 on asa outside so that when i type 10.100.251.81:10444, it redirect me to server 1 (10.100.72.8) when i type 10.100.251.81:10448, it redirect me to server 2 (10.100.72.10)
    i need that when my user hit f5 external ip (41.x.x.x) on port 20444 (41.x.x.x:20444) they are redirected to server 1 and when they hit 41.x.x.x:20445 ther redirected to server 2
    how can i do that ?
  • You need to create a load balancing pool with two members. Members have the same node address but different port.
    tmsh create ltm pool  members add { 10.100.251.81:10444 10.100.251.81:10448 } monitor tcp_half_open
    And the BIG-IP is not redirecting traffic to the pool members it is forwarding the traffic.
    Cheers,
    Kees
  • thanks for your reply. noted for the BIG IP forwarding. I test it now and give a reply.
