ialvaradot_3776's avatar
ialvaradot_3776
Feb 23, 2011
configuration for solving performance issues
i own an f5 BIG-IP 9.4.8 Build 355.0 installed at the end of last year, we had previous versions off5 bigip and i can say we did not have any major problem.
But after migration problems started, basically every week we have to restart the device as internet navigation becomes too slow and some users are continously reporting that external connections to web pages, ftp services, remote desktop connections, and some other external communication services are suddenly broken.
we think it is some kind of spool parameter or something like that that gets full and then with restart is cleaned, well this for the slow navigation problem, but for broken connection we do not have any idea of what could be causing it.
can somebody give a clue?
Regards,
  • hoolio's avatar
    hoolio
    I suggest opening a case with F5 Support on this. It could be a memory leak or other issue that gets worse over time. They'll be able to help troubleshoot the issue.
    Aaron
