thagmann_128177
Mar 25, 2005Compression iRules - GZIP vs. Deflate Preference
F5 DevCentral,
Hi, our understanding is that when doing a Profile that utilizes Compression that BIGIP will prefer the Deflate vs. GZIP method. We would like to have a rule that utilizes GZIP by default.
The current rule we are using to do this is:
b rule force_gzip '{ when HTTP_RESPONSE { [COMPRESS::method prefer gzip] }}'
which gives us
[rootxxxxxxx:Active] config b rule list
rule force_gzip {
When we then associate this rule with a VIP we get an error.
ERROR in /var/log/ltm
Mar 25 22:31:03 tmm tmm[702]: 01220001:3: TCL error: Rule force_gzip - invalid command name "" while executing "[COMPRESS:
:method prefer gzip]"
Do you have any ideas what we might be doing wrong?
Thanks,
-t
- bl0ndie_127134Historic F5 Account
b rule force_gzip '{ when HTTP_RESPONSE { COMPRESS::method prefer gzip ;event disable }}' - bl0ndie beat me to it (and finally when I knew an answer to an iRule question!)
Per the TCL documentation at (Click here) semi-colons and newlines are command separators. So, if you need to include multiple commands on a single line, use a semi-colon to separate them. In the example by unRuleY, "event disable" is a separate command and needs to be delimited as such.
As a side note, I did find a couple of good references for TCL in case you are interested.
Click here for Tcl Reference Manual
Click here for Tcl for Web Nerds
-Joe - thagmann_128177
Thanks guys that took and my compression stats are now incrementing.
Time for Beer 2 today! Many thanks.
-t - thagmann_128177
Doh, I spoke too soon. So my rule took and my Connections are being compressed but when I look at Traces the content-encoding is still set as deflate vs. GZIP.
Is my Rule logic off here?
-t
Here is my rule:
[root@xxxxxx:Active] config b rule force_gzip list
rule force_gzip {
Here is my Virtual:
[root@xxxxx:Active] config b virtual list
virtual VIP1 {
destination x.x.x.x:http
ip protocol tcp
profile HTTP_compress oneconnect tcp
pool LOGIN12
rule force_gzip
Here is my Trace:
GET / HTTP/1.1
Accept: */*
Accept-Language: en-us
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 4.01; Windows NT 5.0)
Host: c.x.x.x
Connection: Keep-Alive
Cache-Control: no-cache
Cookie: MC1=V=2&GUID=xxxxxxx
HTTP/1.1 200 OK
X-Cnection: close
Date: Sat, 26 Mar 2005 00:50:35 GMT
Server: Microsoft-IIS/6.0
P3P:CP="BUS CUR CONo FIN IVDo ONL OUR PHY SAMo TELo"
X-Powered-By: ASP.NET
X-AspNet-Version: 1.1.4322
Set-Cookie: CULTURE=en-US; domain=.xxxx.com; expires=Thu, 26-Mar-2015 00:50:35 GMT; path=/
Set-Cookie: mh=MSFT; domain=.xxxx.com; expires=Thu, 26-Mar-2015 00:50:35 GMT; path=/
Set-Cookie: SPEED=N; domain=.xxxx.com; expires=Fri, 08-Apr-2005 23:50:35 GMT; path=/
Pragma: no-cache
Expires: -1
Content-Type: text/html; charset=utf-8
Vary: Accept-Encoding
Content-Encoding: deflate - thagmann_128177
Still no love. My Traces still show Deflate in the CONTENT-ENCODING Header.... - bl0ndie_127134Historic F5 AccountMr -t, looks like you have found a problem with the Deflate filter. We will try to se what we can do to get this fixed asap, but in the mean time can you give this rule a whirl.
rule gzip { when HTTP_RESPONSE { COMPRESS::method prefer gzip event disable } when HTTP_REQUEST { if {[HTTP::header exist "Accept-Encoding"]} { HTTP::header replace "Accept-Encoding" "gzip" event disable } } } - thagmann_128177
Ok, this workaround seems to work and my CONTENT-ENCODING Headers are now properly showing as GZIP. Getting this fixed soon would be great and since you guys usually GUI-ify any rule that gets alot of use, you should probably add this GZIP vs. DEFALTE Rule to the HTTP Profile in 9.0.
Some questions then:
1.) Is the perf hit on this workaround rule significantly more than the original one?
2.) Based on the way I am interpreting the workaround rule it appears that the top part is the same as the original rule we tried and the bottom part tells BIGIP to re-write the ACCEPT-ENCODING Header request from the Client so that BIGIP never sees the Deflate Option in the Client's request. If this is the case, why do we still need the original rule as part of this workaround rule?
3.) How would the workaround rule handle a situation where my browser supports Compression but only the Deflate method and not GZIP. If I am reading the rule correctly if BIGIP got an ACCEPT-ENCODING Header with just Deflate in it, BIGIP would parse it, see that the ACCEPT-ENCODING Header is present and then just re-write it to GZIP which the Client wouldn't support in this case. Granted I am not sure if there is a Browser version that support only Deflate but I thought I'd ask.
-t - drteeth_127330Historic F5 Account1) Yes. Inserting a header is more expensive than changing some internal state in compression processing. UnRulely recently posted some information about enabling rule timing metrics which could help determine how much more expensive. However, the best way is always to benchmark it.
2) I agree. I don't think you need the original rule.
3) I agree again. You should scan the header value to make sure that gzip is supported by the client before you rewrite it.
I should also mention that I tracked down the problem with the COMPRESS::method prefer command. We'll have it fixed in a future release. - thagmann_128177
So based on all of the changes we talked about, I just want to double-check that I now have the right rule rule that removes the original rule + does the GZIP check in the ACCEPT-ENCODING Header.
I removed the original rule and I am assuming that the "exist" function will scan the entire header and thus instead of matching "Accept-Encoding" we can just match on "gzip". If there's no GZIP then no need to rewrite anything.
Would this rule incorporate everything we talked about so far?
rule gzip2 {
if {[HTTP::header exist "gzip"]} {
event disable
} - bl0ndie_127134Historic F5 AccountYou are very close. The header 'exist' command does not check the header value, it works only on the name. Lets scan the value for 'gzip' and convert it if one found.
rule gzip { when HTTP_REQUEST { if {[string first "gzip" [HTTP::header "Accept-Encoding"]] != -1} { HTTP::header replace "Accept-Encoding" "gzip" } } }
You may want to play around with adding back the 'event disable' command but I suspect that you might have to leave it out for keep-alive connections.
