cory_hase_69275's avatar
cory_hase_69275
Jul 14, 2008
Compression during a M-F 8am-5pm CST window
Can any one tell me if I can enable compression for a VIP via an Irule that will compress for periods of time, based on the local time of the LTM. Like compress duing the day 8-5 else do not compress.
Thanks in advance
  • How about something like this:
     when HTTP_RESPONSE {
       set time_r [split [clock format [clock seconds] -format {%H:%M} ] " "]
       set time_f [expr [expr [lindex $time_r 0]*100] + [lindex $time_r 1]]
       if { not(($time_f >= 0800) && ($time_f <= 1700)) } {
         COMPRESS::disable
    I don't have compression module, so this is untested.
  • Darrell_Kesti_5's avatar
    Darrell_Kesti_5
    Historic F5 Account
    Seeing an error when trying to save this in the iRule editor
    when CLIENT_ACCEPTED {
    set compression "off"
    if { $compression eq "off" } {
    COMPRESS::disable
    line 3: [use curly braces to avoid double substitution] [[expr [lindex $time_r 0]*100]]
    line 3: [use curly braces to avoid double substitution] [[lindex $time_r 0]*100]
    line 4: [parse error: PARSE badNumber 187 {expected integer but got "0800" (looks like invalid octal number)}] [{ not(($time_f >= 0800) && ($time_f <= 1700)) }]
