zafer's avatar
zafer
Nov 08, 2018
Comment Protection
Hi developers keep their comments into the codes, how can i protect/remove this comments with ASM
regards zafer
  • You can use DataGuard feature in ASM . Even though HTML comments are not credit card / Social Security numbers they can still be sensitive data which should not leak to attackers.
    Dataguard can mask the sensitive data with asterisks and raise a violation when comment is found.
    You will need a Regular Expression for HTML comments, here is an example:
    https://blog.ostermiller.org/find-comments-html
