Command Line Help
Please excuse me if this question has been answered. I am rather new with using the F5 product and would love some direction. I want to be able to do most of my work through the command line and am running into a road block. Is it possible to cut and paste config into the command line that I need? I need to be able to create a Pool, Virtual Server, and Monitor with just a cut and paste from a text file. Any direction would be much appreciated.
- John_Buchanan
What version are you running? I'd start with the TMSH reference guide, here's the link for 11.6.0, https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmsh-reference-11-6-0.pdf - eben_240222
Sure you can copy and paste configs to the CLI. you have to be in tmsh mode to do that.
- itchmyhead_2560
It appears that I am in TMSH mode. Are there any specific examples of how you write the configurations up?
- Michael_Jenkins
You can use the
command withinload sys config from-terminal merge verify
and then paste the new/updated config and then hittmsh
to execute. That command will verify the changes.Ctrl + DThen you can use the
command and paste the config andload sys config from-terminal merge
to actually update the config.Ctrl + DNote: You don't have to do the verify before the merge, but it makes me feel safer knowing there's not conflicts or syntax errors in the config
