FRANCISCO_01
3 years agoCommand Delete the connection table entries and lost monitor
The scenario is as follows:
SOURCE ip 10.10.20.x
VIRTUAL DESTINATION 10.10.2.x
PORT 636
The command was applied
tmsh delete /sys connection cs-client-addr 10.10.20.2 cs-server-addr 10.10.2.2 cs-server-port 636
When applying the command, the servers that belong to the POOL stopped being seen by the MONITOR, the command was applied to the virtual IP and not to the servers that belong to the POOL.
When applying the DELETE command, the MONITOR did not have to be lost since it is only affecting specific connections and every time this command is applied, the monitor that is applied to the destination servers is lost.
Has this happened to you or do you know if it is due to a BUG or problem? The version that is being handled is 14.1.4.3 BIG-IP1 Reply
I see that another person made the same post and maybe it is the same issue? I see that is LDAPS is the port in the two cases so could it be that it is for the same devices?
https://community.f5.com/t5/technical-forum/bug-with-delete-connection-command/td-p/297716
