Gianluca_Nuzzo_
Oct 24, 2017Client Self-Signed Certificate require and forward as header
- normal traffic hit on 443 is terminated and forwarded as new session to the web servers
- specific URL should request client certificate, the validation performed on the backend server, accepting self-signed certificates received on a header
We have the following iRule implemented, but failing to successfully accept the self-signed certificate sent back after the renegotiation... Any idea on how we can fix it ?
Thank you
when CLIENT_ACCEPTED {
set session_flag 0
when CLIENTSSL_HANDSHAKE {
if { [SSL::cert count] != 0 } {
log local0. "Received client cert, releasing HTTP request."
HTTP::release
switch -glob -- [string tolower [HTTP::uri]] {
"/service" {
if { [SSL::cert count] == 0} {
HTTP::collect
set session_flag 1
SSL::authenticate once
SSL::cert mode require
SSL::renegotiate
HTTP::header insert X-ENV-SSL_CLIENT_CERTIFICATE [b64encode [SSL::cert 0]]
default {
log local0. "No certificate needed for: [HTTP::uri]"
- Lee_Sutcliffe
Nacreous
Try replacing the CLIENTSSL_HANDSHAKE event with CLIENTSSL_CLIENTCERT
