client connection persistence
We have 2 source and i am trying to force each source to 1 node behind the lbs. Below irule is not working as expected I see a reset from f5 no traffic passing to the pool member
when CLIENT_ACCEPTED {
# get the default load-balancing pick
set mypick [LB::select]
if { (([IP::client_addr] == "192.168.1.2") && ([LB::status pool qa_443 member 10.12.4.252 443] eq "up")) } {
elseif { (([IP::client_addr] == "192.168.1.3") && ([LB::status pool qa_443 member 10.12.4.253 443] eq "up")) } {
# the default pick is chosen
eval $mypick
Hi Sam10,
Can you try this?
when CLIENT_ACCEPTED { if { ([IP::client_addr] equals "192.168.1.2") && ([LB::status pool qa_443 member 10.12.4.252 443] eq "up") } { pool qa_443 member 10.12.4.252 443 } elseif { ([IP::client_addr] equals "192.168.1.3") && ([LB::status pool qa_443 member 10.12.4.253 443] eq "up") } { pool qa_443 member 10.12.4.253 443 } else { pool default_pool } }did that work Sam10?
