dlg_23340's avatar
dlg_23340
Icon for Cirrus rankCirrus
Nov 18, 2011
[class exists $redir_class]
Hello, all. I have an irule that needs to check if a class exists, then if it does, pull a record from it. If not, it should do nothing. in this case, the value contained in redir_class does not exist as a class name.
      if { [class exists $redir_class] } {
        log local0. { [class match -value -- [HTTP::uri] starts_with $redir_class]}
        log local0. { class $redir_class does not exist}
I would expect to see " class x does not exist" in my logs, but instead i get this:
"TCL error: testirule - Could not find class x"
If i replace the [class match...... with a simple text string to log, i get the expected behavior. Why would it try to process code in a block that doesn't match?
Thanks,
David
  • George_Watkins_'s avatar
    George_Watkins_
    Historic F5 Account
    Hi David,
    It looks like you're almost there. One thing that I think may be throwing you off is the logging messages. The curly braces around your log commands will prevent variable substitution and command execution. Here is the iRule and datagroup I used to test with.
    ltm data-group internal /Common/test_vars {
        records {
            /var1 {
                data 4
            /var2 {
                data 8
        type string
    ltm rule /Common/test_vars_class_exists_2156869 {
      set redir_class test_vars
        log local0. " [class match -value -- [HTTP::uri] starts_with $redir_class]"
        log local0. " class $redir_class does not exist"
    Here are the results I got while testing various URIs:
    http://test-http-vs/var1 => Nov 18 07:35:42 tmm info tmm[14987]: Rule /Common/test_vars_class_exists_2156869 :  4
    http://test-http-vs/var2 => Nov 18 07:35:49 tmm info tmm[14987]: Rule /Common/test_vars_class_exists_2156869 :  8
    http://test-http-vs/foo1 => Nov 18 07:35:55 tmm info tmm[14987]: Rule /Common/test_vars_class_exists_2156869 :
    -George
  • With the exact same class and rule, what happens if you set redir_class to something other than "test_vars"? That's the case I think he is trying to demonstrate.
    George_Watkins_
    Historic F5 Account
    I'm getting the expected behavior when $redir_class is undefined or the referenced class doesn't exist on v11.0.0 (build 8037):
    Nov 21 06:01:50 tmm err tmm[20592]: 01220001:3: TCL error: /Common/test_vars_class_exists_2156869  - can't read "redir_class": no such variable     while executing "class exists $redir_class"
    Nov 21 06:02:14 tmm info tmm[20592]: Rule /Common/test_vars_class_exists_2156869 :  class ttt does not exist
    This sounds like it could be a problem with the version of LTM you are running. What version are you testing on?
    -George
  • mine is 10.2.3.
    [root@ve1023:Active] config  b version|grep -iA 1 version
    BIG-IP Version 10.2.3 112.0
    Final Edition
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
            if {[class exists $redir_class]}{
                    log local0. "[class match -value -- [HTTP::uri] starts_with $redir_class]"
                    log local0. "class $redir_class does not exist"
    [root@ve1023:Active] config  curl -I http://172.28.19.79/var1
    HTTP/1.1 404 Not Found
    Date: Tue, 22 Nov 2011 11:35:21 GMT
    Server: Apache/2.2.3 (CentOS)
    Connection: close
    Content-Type: text/html; charset=iso-8859-1
    Nov 22 03:35:07 local/tmm info tmm[24220]: Rule myrule : 4
    [root@ve1023:Active] config  curl -I http://172.28.19.79/var2
    Date: Tue, 22 Nov 2011 11:35:24 GMT
    Connection: close
    Nov 22 03:35:10 local/tmm info tmm[24220]: Rule myrule : 8
    rule myrule {
            set redir_class fake_test_vars
    Date: Tue, 22 Nov 2011 11:35:58 GMT
    Connection: close
    Nov 22 03:35:43 local/tmm info tmm[24220]: Rule myrule : class fake_test_vars does not exist
