Changing Default Pool for VIP - Graceful?
We are looking at how we can do our deployments, such as blue / green style deployments
If I have a VIP and change the default pool from pool a to pool b, will connections that are in progress complete gracefully as per a force offline?
if not I'm guessing the other option is that we add new servers to the pool and gracefully remove the old ones from the pool?
David
- shaggy
from my experience, F5 usually handles most configuration changes to a virtual server/pool gracefully.
i also tested it out, and my connection to the old pool member was maintained:
- connected to a VS
- saw my connection using "show sys connection cs-server-addr " tied back to an "old" pool member
- changed the default pool of the VS to which i was connected
- the session from my PC did not drop
- saw the connection still existed to the "old" pool member using "show sys connection cs-server-addr "
