Wynand_van_Nisp's avatar
Wynand_van_Nisp
Sep 12, 2006
Change URI after evaluation and still load balance
Hi everyone,
I have a customer with a strange request. The want to specify in the URI which pool to use, then strip the part that identify it and continue with the load balance. My irules are not up to scratch yet and I have done this so far but get stuck on the removal of the "prd/" and "ppd".
Any help will be appreciated.
---- snip ----
if {[HTTP::host] contains "soa"} {
if {[HTTP::uri] starts_with "/prd/"} {
Remove prd/ here
pool POOL_SOA_PRD
if {[HTTP::uri] starts_with "/ppd/"} {
Remove pPd/ here
pool POOL_SOA_PPD
else {
THIS IS ONLY HERE SO THAT THEY CAN KEEP TESTING
pool POOL_SOA_PRD
Thanks in advanced.
Wynand
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    You could do this a couple of different ways. One way you might try is with the string trim left command.
    Something like
          HTTP::uri [string trimleft [HTTP::uri] /prd]
          pool POOL_SOA_PRD
          HTTP::uri [string trimleft [HTTP::uri] /ppd]
          pool POOL_SOA_PPD
          pool POOL_SOA_PRD
    Colin
