Magnum_IP
Jun 08, 2011Certificate removed from ca-bundle between 10.2.0 and 10.2.1
This may be the wrong topic group for this one, if so apologies and please advise...
I was recently involved in an upgrade from 10.2.0 to 10.2.1. After upgrading we had issues with an HTTPS Virtual Server, connections were being reset. To cut a long story short it was due to the 'VeriSign Class 3 Public Primary Certification Authority - G5' certificate being removed from the ca-bundle in 10.2.1.
A bit of googling uncovered an f5 Known Issue doc (http://support.f5.com/kb/en-us/solutions/public/12000/700/sol12753.html) which states the cert was removed but there is not really enough detail there for me to really understand why.
My client has purchased a certificate signed by this CA cert, should I or should I not be importing it into the BIG-IP and assigning it to the Virtual Servers Client SSL Profile to get things back up and working? Has my client purchased the wrong kind of certificate?
Regards,
fergu5
- nitass
Employee
what is your verisign certificate product e.g. secure site, secure site pro, etc?
verisign new intermediate certificate should have two certificates; one is secondary and the other one is primary. the secondary is on top of the file.
https://knowledge.verisign.com/support/ssl-certificates-support/index?page=content&actp=CROSSLINK&id=SO14649
also, this is installation checker
https://knowledge.verisign.com/support/ssl-certificates-support/index?page=content&id=AR1130&actp=LIST&viewlocale=en_US - Magnum_IP
Here is the certificate hierarchy...
VeriSign Class 3 International Server CA - G3
mydomain.com
My client had an initial certificate which they renewed, the renewal was signed by with the G3 and G5 certs.
The G5 cert was in the ca-bundle up until we upgraded to 10.2.1 - not sure why f5 have removed it if VeriSign are signing certificates with it. Any clues?
fergu5 - Michael_Yates
If you look at the top of the ca-bundle.crt file, they list where they get the updates:
This is a bundle of X.509 certificates of public Certificate
Authorities. It was generated from the Mozilla root CA list.
Source: mozilla/security/nss/lib/ckfw/builtins/certdata.txt
Generated from certdata.txt RCS revision 1.56
You can download updated CA-Bundles here: http://curl.haxx.se/docs/caextract.html
That might be a good place to start investigating why it was removed, but you can also add it back in if you like. It is just a collection of the most common root certificates.
Hope this helps. - nitass
Employee
r u using client certificate authentication?
bug id 338848 is about bigip not sending all intermediate certificates to client which leads to certificate warning message on browser. i don't think connection is reseted.
