sandiksk_35282's avatar
sandiksk_35282
Mar 07, 2018
cert issue
I am running into any issue with one of the VS on F5. We have SSl certs to decrypt the client traffic. But when users try to access the site they get the unable to get local issuer certificate (20), continuing anyway error.
in client ssl profile . I have the intermediate cert and the key and in the chain have the root cert. Do i need import all the certs bundle under the certificate.
  • You need to add root CA in the client browser if you are using an internal CA signed cert.
    -Jinshu
  • No client certificate CA names sent SSL handshake has read 2039 bytes and written 495 bytes
    New, TLSv1/SSLv3, Cipher is DHE-RSA-AES256-GCM-SHA384 Server public key is 2048 bit Secure Renegotiation IS supported Compression: NONE Expansion: NONE SSL-Session: Protocol : TLSv1.2 Cipher : DHE-RSA-AES256-GCM-SHA384 Session-ID: C64160D953DD6B228EAF7E129812AEDCB7EA85734C479F8AF28AC7AC13E42E30 Session-ID-ctx: Master-Key: E89D1B31F7B19C01083878F882041675A80B370EACDAC5EA33F4A20CD88E80DABD72A2CE841326E9C19862593C447665 Key-Arg : None PSK identity: None PSK identity hint: None Start Time: 1520463060 Timeout : 300 (sec)
    Verify return code: 21 (unable to verify the first certificate)
