rohitbarolia_28's avatar
rohitbarolia_28
Mar 19, 2019
Solved
Capturing source IP addresses for VIP
Is it possible if we can capture all the source IP that are hitting our VIPs.
  • Yeah, You can capture client IP address via iRule or X-Forwarded-For.
    For more information go through below F5 Article.
    Option 1: X-Forwarded-For HTTP header K4816
    Option 2: iRule
            log local0. "clientIP:[IP::client_addr] accessed [HTTP::host][HTTP::uri]"
    Hope your issue will be solved..
  • M_2's avatar
    M_2
    HI,
    Yes it is possible to capture the soruce Ip addresses hitting the vip using irule, in case if you want to see it on the backend server (running http), you can try enabling XFF (X-Forwarded-For) option to see the cient IP in headers at server side (webserver.)
    -M@rcus
    Option 2: iRule
    • rohitbarolia_28's avatar
      rohitbarolia_28
      We are looking for a way to look at the historical connections for a particular vip, Is it something we can achieve through enterprise manager (EM).
    • M_2's avatar
      M_2
      Have not see any such feature for historical connections using EM, but BigIP F5 LTM - Application Visibility and Reporting module can be helpfull.
