Narendra_65803's avatar
Narendra_65803
Nov 04, 2010
Capturing Credit Card Data using iRule
Hello Everyone,
I am very one here. My company is providing PCI DSS solution to customer and one of them is protecting credit card data.
I would like to use iRule for capturing Credit card data from HTTP / HTTPS traffic when it passes through f5 and converting actual credit card data into dymmy card number / token number. I heard that I can do using f5 with iRules but could not get any success.
Can any one please help me how to achive this goal.
  • HI Narendra,
    Have you taken a look at the code share for Credit Card Scrubbing
    http://devcentral.f5.com/wiki/default.aspx/iRules/CreditCardScrubberUsingStream.html
    http://devcentral.f5.com/wiki/default.aspx/iRules/CreditCardScrubber.html
    Bhattman
  • hoolio's avatar
    hoolio
    The stream based iRule Bhattman linked to should be an efficient way to do this.
    If you wanted to avoid rechunking responses, you could add logic to the STREAM_MATCHED event to replace the actual credit card number with a dummy string of the same length.
    Aaron
