Capturing Application traffic without using AVR
hi,
Can we capture application traffic on LTM without using AVR to investigate latency issues?
- Yann_Desmarest_
Nacreous
You can use tcpdump through CLI or you can define a clone pool to your Virtual Server.
Then, you will need some extra software to calculate latencies.
Bye
Yann
- Allwin_179373
Hi Yann,
Could you please clarify on the Virtual Server Clone pools?
Also can you share what extra softwares will be required?
- Yann_Desmarest_
Nacreous
Hi Allwin,
There is an article describing this feature.
You can then use third party software like Splunk, Riverbed, Dynatrace, ...
Bye
Yann
- Allwin_179373
Hi Yann,
Hi Allwin,
