SS11's avatar
SS11
Jun 06, 2018
Capture the receive string in health monitor
Application designer asked to setup a receive health monitor and the request is below;
ADC(any characters except {)Running (trying to match this: "system": "ADC", "status": "Running", ) but not subsequent occurrences of "Running", in total output that looks like this:
{ "system": "ADC", "status": "Running", "date": "05-22-2018 18:36:23:913", "details": [ { "service": "Terminology", "description": "Terminology Web Service", "status": "Running", "details": [ { "web_service": "Running" } ] } ]
I tried with [^\w]\"system\":\"ADC\",\"status\": \"Running\" and \"system\":\"ADC\",\"status\": \"Running\" but it doesnt work. what is the correct format to match the receive string?
  • Hi,
    Firt of from CLI can you try your query using CURL? In order to see that response. In this way you can validate your request and check response. curl example:
    curl -i -k [https://1.1.1.1/url](https://1.1.1.1/url) -H "Host: myappname.domain.com"
    where 1.1.1.1 is your backend server and myappname.domain.com the app hostname
    if the backend is not ssl/TLS try this:
    curl -i [http://1.1.1.1/url](http://1.1.1.1/url) -H "Host: myappname.domain.com"
    Let me now if it's clear or you need additional info (add parameter or other)
    regards
  • JG's avatar
    JG
    It looks like
    is already a unique string in the output. So why not just use:
    \"system\": \"ADC\", \"status\": \"Running\",
    as the receive string, rather than looking for the first occurrence of "Running"?
  • JG's avatar
    JG
    So the output is really in multiple lines, not in a single line as it was originally posted:
      "system": "ADC",
      "date": "06-07-2018 03:48:12:859",
      "details": [
          "details": [
    If so, you can try the following instead:
    { "system": "ADC", "status": "Running", "date": "06-07-2018 03:48:12:859", "details": [ { "service": "Terminology", "description": "Terminology Web Service", "status": "Running", "details": [ { "web_service": "Running" } ] } ]
    . This will capture the first occurrence of "Running" with the correct context, no?
    [Edited to replace all spaces with
    \s\s\"system\":\s\"ADC\",\n\s\s\"status\":\s\"Running\",\n
     to avoid confusion due to incorrect code display.]
