T31's avatar
T31
2 years ago
Solved
Capture part of URI and do not redirect.
I am doing redirection for path like this:
/abc (and whatever parameters after /abc) is being redirected to /xyz
if { [HTTP::host] contains "example.com" }{
elseif { [HTTP::uri] starts_with "/abc" } {
HTTP::redirect /xyz
My new requirement is:
If the uri is /abc (and whatever parameters after /abc, eg: /abc?=un), it should redirct to /xyz
If the uri is /abc-def (and whatever parameters after /abc-def, eg: /abc-def?=un, it should stay on same URI /abc-def
Could you please let me know how this can be acheived? Thanks
  • Thank you all for your help.
    I write this irule and solve my problem.
    elseif { [HTTP::uri] starts_with "/abc" and not ([HTTP::uri] contains "abc-def") } {
    HTTP::redirect /xyz
    This is what happening.
    example.com/abc -> redirecting to example.com/xyz
    example.com/abc?=un -> redirecting to example.com/xyz
    example.com/abc-def -> It stays as it is. This is my requirement.
    example.com/abc-def?=un ->  It stays as it is. This is okay for me now.
    I was looking if there is anyway example.com/abc-def?=un can also be redirected to example.com/abc-def by modifying the irule above.
  • I think you can just replace:
    with:
    [HTTP::path] equals "/abc"
  • I think you need to use (not starts_with) operator for your logic.
    In the below code sample, if the request equals to "abc" or not starts with "abc-def", it will be redirected to /xyz.
    Therefore,
    "If the uri is /abc (and whatever parameters after /abc, eg: /abc?=un), it should redirct to /xyz
    If the uri is /abc-def (and whatever parameters after /abc-def, eg: /abc-def?=un, it should stay on same URI /abc-def"
    • /abc will be redirected to /xyz
    • /abc?=un will be redirected to /xyz (because it is not starts with "abc-def"
    • /abc-def will stay on same because it will not going into second if statement.
        if {[HTTP::host] eq "www.example.com"}{
            if{(([HTTP::uri] eq "abc") or !([HTTP::uri] starts_with "abc-def"))  }{
            HTTP::redirect "www.example.com/xyz"
  • T31's avatar
    T31
    HTTP::redirect /xyz
  • when HTTP_REQUEST {
        set HOST [string tolower [HTTP::host]]
        set URI [HTTP::uri]
        if { $HOST equals "example.com" } {
            if { $URI equals "/abc-def?=un" } {
                HTTP::redirect "/abc-def"
                return
            } elseif { $URI starts_with "/abc" && !($URI contains "abc-def") } {
                HTTP::redirect "/xyz"
    • T31's avatar
      T31
      Thanks. Make sense.
