admin_xk_99638
Mar 12, 2012can't read "need_cookie": no such variable
Hi All, Encounter the following errors.
Mar 9 10:00:01 local/tmm err tmm[4875]: 01220001:3: TCL error: MAGIC-iRules - can't read "need_cookie": no such variable while executing "if {$need_cookie == 1} { HTTP::cookie insert name "magicClientName" value "TM2003218" HTTP::cookie insert name "TM2003218" value $client_id..."
Any advice on this?
Is it because the need_cookie contains the special characters?
- nitass
Employee
Is it because the need_cookie contains the special characters?i do not think so.
Any advice on this?may you post the whole irule? - admin_xk_99638
when RULE_INIT {
; set ::total_active_clients 0
; set ::max_active_clients 3000
set ::holding_page_be "http://www.testing.com"
set ::debug_mode 0
log local0. "rule session_limit initialized: total/max/debug_mode: $::total_active_clients/$::max_active_clients/$::debug_mode"
; test cookie presence
if {[HTTP::uri] contains "maxLimit.do"} {
if {[HTTP::cookie value "SeatOfferPage"] == "successful"} {
log local0. "TE kick out user after step 1!"
if {[HTTP::cookie exists "TM2003218"]} {
set need_cookie 0
set client_id [HTTP::cookie "TM2003218"]
; if cookie not present & connection limit not reached, set up client_id
;log local0. "old client id $client_id, current number $::total_active_clients"
if {$::debug_mode >= 4} {log local0. "Returning customer with cookie value: $client_id"}
if {$::total_active_clients < $::max_active_clients} {
if {[HTTP::uri] contains "SeatAvailability.do"} {
set need_cookie 1
set client_id [format "%08d" [expr { int(100000000 * rand()) }]]
if {$::debug_mode >= 1} {log local0. "1-New customer with cookie value: $client_id, IP:[IP::client_addr], total_active_clients: $::total_active_clients"}
incr ::total_active_clients
; otherwise redirect
;log local0. "new client id $client_id, current number $::total_active_clients"
; set need_cookie 2
if {$::debug_mode >= 2} {log local0. "Excced limit now, total_active_clients: $::total_active_clients"}
HTTP::respond 302 Location $::holding_page_te "Cache-Control" "no-cache" "Pragma" "no-cache"
return
when HTTP_RESPONSE {
; insert cookie if needed
; if {$need_cookie == 2} {
; HTTP::respond 302 Location $::holding_page_te "Cache-Control" "no-cache" "Pragma" "no-cache"
; return
when CLIENT_CLOSED {
; decrement current connection counter for this client_id
if {$::total_active_clients > 0} {
incr ::total_active_clients -1
if {$::debug_mode >= 1} {log local0. "Client dropped, total_active_clients: $::total_active_clients"}
} - admin_xk_99638
Upz.. - Moe_Jartin
Cirrus
It looks like you are only setting the need_cookie variable under certain conditions. So on any requests where those conditions are not met the variable $need_cookie is not set.
You need to ALWAYS set the need_cookie variable to some value (like at the top of the irule where you are setting the other variables) since you are calling for it unconditionally under the HTTP_RESPONSE event. Hope that makes sense.
-Joe - admin_xk_99638
if I insert set ::need_cookie below the set ::debug_mode 0 does it helps? Will it considered as setting it as global variable? - nitass
Employee
shouldn't need_cookie be local variable rather than global one?
instead of setting it in RULE_INIT, i think it should be initialized in HTTP_REQUEST.
