AndyC_86542
17 years agoCan an F5 route and use iRules on the same packet
I want to do something like this:
Check an http request for a specific cookie. If the cookie isn't there then respond with an http redirect. I can do this fairly easily using iRules.
Otherwise (if the cookie is there) route the traffic onwards to a pool of transparent proxy servers which can access the web (so a default router pool in effect). I have failed miserably to get this second part to work.
Is this possible? Any suggestions how?
- AndyC_86542
Just for interest, I've been trying to do it so far using a virtual server (0.0.0.0:0) to which I apply the irule. - hoolio
I'd suggest creating a 0.0.0.0:80 VIP (wildcard vip on a specific port) with an HTTP profile. You should then be able to use a rule like this to check for the cookie:when HTTP_REQUEST { Check if the cookie exists if {[HTTP::cookie exists "my_cookie"]}{ Use the proxy pool pool proxy_pool } else { Redirect the client HTTP::redirect "http://redirected.example.com" } }
You might want to try adding some kind of validation of the cookie value as the above example could be bypassed by a client manually inserting a cookie with the name.
Aaron - AndyC_86542
That makes sense. What does the proxy_pool include exactly (I think this is where our problem lies). Does it include router or proxy IP addresses, or something else entirely. - hoolio
If the proxy servers can be routed to, you could add them to a pool and specify that in the rule. If you want to forward the requests with the cookie according to LTM's routing table, replace 'pool proxy_pool' with 'forward'.
Aaron
